Which gears with a 100 shot 6 speed?
Old Dec 27, 2005 | 03:19 AM
JPH910's Avatar
Default Which gears with a 100 shot 6 speed?
What gears should I use on a mostly street drivin 6 speed with a 100 shot?
Old Dec 27, 2005 | 11:41 AM
TonyJ's Avatar
I like the 3:42s in my Z06, but lot's of f-body guys seem to favor the 3:73s
Old Dec 27, 2005 | 11:44 AM
Noyzee's Avatar
8 second mod
i liked the 3:73, the 4:10's would work a tad better, but not as streetable.
Old Dec 27, 2005 | 11:50 AM
white2001s10's Avatar
Between 3.42 and 3.73
With a 6-speed it's more a matter of getting through the traps in fourth gear, so it all depends on what your trap speed is going to be.
If you're going to stay stock with a 100 shot, then the 3.73's will be better for you.
If you're going to do a N/A build-up on top of the 100 shot, or go up to a 200 shot, then 3.73 may end up too much.
Old Dec 27, 2005 | 11:56 AM
Noyzee's Avatar
8 second mod
if you build up the car for na then put the 100 shot, that means your red line jumped up to 6,800 or so, and 3:73 should work.
i went 10.6 @ 133 with my turbo setup, 6 speed and 3:73 with a 27" tire
Old Dec 27, 2005 | 02:32 PM
Robert56's Avatar
M6, street/strip 3.73, M12 street/streep 3.42, imo.
Robert
Old Dec 27, 2005 | 02:55 PM
Silver 00 SS's Avatar
3.73 gears work great
Old Dec 27, 2005 | 03:09 PM
n2o's Avatar
n2o
4.10's are too much. Your tire choice plays a key roll in this as well.
Old Dec 27, 2005 | 04:27 PM
STANG KILLA SS 2's Avatar
4.10s. i have them in my daily driver. its not too much. youll be wasting your time and money on the 3.73s (u WILL be disappointed trust me)
Old Dec 27, 2005 | 04:35 PM
Unstang's Avatar
4.10s work well with nitrous!
Old Dec 27, 2005 | 06:04 PM
slmdLS1's Avatar
ill stick with 4.10's as i wont always have the N2o readily available...
Old Dec 29, 2005 | 09:12 AM
wilddawg's Avatar
3.42 reason being you cannot shift fast enough to stay off the rev limiter with a 100 shot
Next on street tires anymore gear is going to spin worse
Nitrous makes a bunch of torque and that is what gets you moving a 3.42 gear will keep you in your torque range longer and you will shift less
Old Dec 29, 2005 | 09:17 AM
Noyzee's Avatar
8 second mod
i would disagree. if you can drive, you can get around the limiter.
and you will shift 4 gears in the 1/4 weather you have 3:73 or 3:42's. so the shift less theory is gone.
if you drove a car with 3:42's and then 3:73 you could barly tell anything was done.
Old Dec 29, 2005 | 09:27 AM
wilddawg's Avatar
I agree with the gear change theory as you stated that is why I see no reason to change gears. the 10 bolt is going to go sooner or later so save that money towards a good rear end. As for the shifting everyone skill level is different. You can get around the limiter with a window switch to be safe and not have a bunch of broken rocker arms. On the gas I really don't see it being necessary to change gears. Just some sticky tires and a window switch.
Old Dec 29, 2005 | 09:29 AM
jerflash's Avatar
4.10 is the choice
great when off the juice and when you wana juice it put the 28" tire on and juice all you want
Old Dec 29, 2005 | 09:43 AM
Noyzee's Avatar
8 second mod
no rev limiter. just jump the rpm way up with a tuner, and shift where you want.
i agree on the 12 bolt thing tho
Old Dec 29, 2005 | 12:41 PM
wilddawg's Avatar
Well the thing is how much money he is willing to spend for a 100 shot that works well for the stock car. I will get some one with a Tuner to move the limiter or buy a tuner. save money on gears for a 12 bolt in the near future. Just curious how far is way up on the limiter will a stock motor go without floating the weak valve springs from stock. How much will it stand for a short period of timen Nos
Old Dec 29, 2005 | 01:01 PM
OOOJOHN's Avatar
410s are very streetable . I love them.
Old Dec 29, 2005 | 01:13 PM
Robert56's Avatar
On the 4.10's, on the Z06/M12, 1st is geared like having 4.10's, second is like having 3.90's, third is like 3.73's and fourth is back to the stock 3.42's, pulls like a *****, and has a killer top end. Yes, when spraying the shifting better be done quickly as rpms come up fast. I have my limiter set higher than stock 6800rpm. Something to keep in mind, when going to 4.10's, because of the additional teeth on ring/pinion it is actually weaker than a 3.73/3.90 gear sets with bigger less teeth.
Robert
Old Jan 1, 2006 | 06:05 PM
mike c.'s Avatar
i have 4.11's 12bolt 26'' slick w/150 shot. my rev is set at 7,200 and shift at 6,600-6,700
