NX versus Ny-trex nozzle
Robert
you know me, i taint all my stuff.
there is so many ways this could go. solenoids, nozzles, bottle valves.
which by the way, the onlt time i used the nytrex bottle was for the first run. the rest of them i stayed with my compucar bottle. and i verified that not be be a contributing factor when i redid the nozzle test for test 4 comparing both nozzles with the larger solenoid. 6 rwhp gain on test 4 swapping nozzles. 8 rwhp was the first test.
which now brings up another thought, what really is the max point of solenoids? 80% like ken suggests? or lower? it's obviously not higher.
back when i did a 150 to 200 last year on my black car, i only received less than 10 rwhp gain.
in this case, bigger is better
Robert
.062/.033
NX (and some others)150 rwhp
Ny-trex (and some others) 150 motor
the compucar is a small solenoid as well. so, i know just going to a larger solenoid will net me another 18 rwhp. right now my restriction is the noids.
what is a 'safe' a/f ratio on the bottle? 11:1? 12:1?, 13:1? obiviously, i'm making more power at a higher a/f ratio. but, is 6-8 rwhp worth the .5-1 point leaner condition? current in the 12.5:1 range that is.
On your setup I may be inclined to get closer to 12.0 from your current 12.5. But If I was at a very steady 12.5 and have determined there was no knock anywhere I could live with that as well. If you had knock I would address timing first at that point anyways. Your in the ballpark IMO.
I think 11 is too much. If you wanted 11.5 that would be fine as well but it may cost you a bit...tough to say without checking. If it were my car I would go to 12.0 with a 150 shot. But at the track I would still be inclined to run a few gallons of 100 unleaded. Its cheap insurance and goes a LOONG way towards safety. Especially if your going to be hitting it in the lower rpms like you generally like to.
