Accessory Guages?
Old Jan 2, 2006 | 01:20 PM
LS1BlackBird99's Avatar
Default Accessory Guages?
Do you guys think I will need any spare guages for my setup? I was wondering if it was really needed or not w/my nitrous. I want something fairly cheap if it is.
Old Jan 2, 2006 | 02:50 PM
BadAssFast's Avatar
I like N20 Pressure and Fuel Pressure gauges. I'll eventually do an AFR once the system is in place to warrant it. Just what I run. You thought about running TR6 plugs?
Old Jan 2, 2006 | 04:30 PM
bad6as's Avatar
i was thinking about n20 and was gonna get a fuel psi, n20 psi, and a air to fuel ratio
Old Jan 2, 2006 | 06:19 PM
The Sad's Avatar
I am going to get n2o press, fuel press and tranny temp - due to the high stall. (you should get a stall verter BTW)
Old Jan 2, 2006 | 09:56 PM
Do yall use them in the pillar setup or where else? I thought replacing some of the vents would be cool but wasn't sure how hard that would be or if some place a special setup just for that?
