Max HP with NOS 5177 Dry Kit?
Old Jan 3, 2006 | 02:02 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
Default Max HP with NOS 5177 Dry Kit?
Due to the size of the line, this kit will only make a certain amount of horsepower through certain jets. My question is, approx. how much hp will it make through:
2-NOS 36 jets
2- NOS 38 jets
2- NOS 40 jets
In other words, at some point, no matter how big the jet, the hp will be the same because the line can only supply so much gas.
Old Jan 3, 2006 | 02:07 PM
CamdLs1's Avatar
Running no jets I think it is a 175 shot, or somewhere close to it.
Old Jan 3, 2006 | 02:12 PM
11 & 7 Second Clubs
I haven't tried it on the dyno, but when I went from 2-36 jets to 1-36 and 1-40 jet I noticed an improvement in power, and I was wondering if the kit could make 200 hp with any combination of jets. I know it would with a larger line diameter.
Old Jan 3, 2006 | 03:04 PM
n2o's Avatar
n2o
Split the solenoids up and you can. That way you wouldn't need a larger line.
Old Jan 3, 2006 | 03:13 PM
CamdLs1's Avatar
The bottleneck is the noids, even with a bigger line.
Old Jan 3, 2006 | 03:46 PM
n2o's Avatar
n2o
No what I am talking about is running them seperate. Could do a two stage or have them both come in at the same time. Just have a feed going to each one.
Old Jan 3, 2006 | 03:59 PM
GM Muscle's Avatar
Without splitting up the noids the most you will see is only about 140-150rwhp. The solenoids are only rated to flow about 175hp at the crank as mentioned above. If you spilt up the noids you will be able to make 200rwhp no problem. A -4an feedline will support that plus some.
Old Jan 3, 2006 | 06:13 PM
Robert56's Avatar
If you take your supply line (a -4 line under ideal conditions will support a 400hp shot) and run it to the blue fitting holding the two noids together (pipe plug in hole), then take one noid and turn it around (so both are in/out correct) you'll have about a 300rwhp shot. It's been done many times and proven. so then you have one noid suppling each nozzle, and you can dual stage it this way also. I have two 5177 kits set up this way so I still retain redundant noids, and also have quad nozzles, and dual stage.
Here's a schematic from a link in my web site:
Robert
Old Jan 3, 2006 | 07:43 PM
CAT3's Avatar
Restricted User
Damn, look at Robert making MS Paint look good! Nice diagrams and info, as always.
Roberts description is how I have mine setup, one noid filling the two nozzles, one filling a custom dual exiting nozzle. I havent put any jets in, but I will end up limiting one of the noids a little. I only want to launch and run off a 200shot at first
Old Jan 3, 2006 | 08:09 PM
11 & 7 Second Clubs
Robert,
That is one **** of a reply. It might be the best I've gotten. I'm doin it.
Old Jan 4, 2006 | 08:48 AM
95ttoplt1's Avatar
Hey rob could you do the same with a 5176 kit?
Old Jan 4, 2006 | 07:21 PM
Robert56's Avatar
That's the lt1 dry kit. I am not sure on this. I have heard of no one doing it with that kit. I think the dual noids work a little different on that kit, the first noid opens and allows nitrous to go through the FMU, then to the second noid, so splitting them up? I really can't answer this as an absolute, maybe call NOS tech. Here's something that most do not realize, the 5176 can be used on 97/98 C5's. The reason being is they use a vac ref type regulator at the rails, so you can do a dry on these cars by bypassing the MAF. Why haven't we seen this, beats me. I almost did it on my '97 c5 but opted for a MAF dry (5177).
Robert
Edit: One thing though, if your using the 5176 on a lsx car and drop the FMU and stick nozzle(s) before the maf, then yes it's doable.
Old Jan 4, 2006 | 07:51 PM
95ttoplt1's Avatar
This would be an LT1 so I guess not, thanks for the reply
Old Jan 4, 2006 | 07:56 PM
cablebandit's Avatar
Robert thanks for that informative reply and diagram...should be a sticky!!!!
Old Jan 5, 2006 | 01:02 AM
z28viperkiller's Avatar
The 5176 kit worked great on my 1995 lt1. The fmu sends about 50-55psi of nitrous to the nipple on the fp regulator, with a bleed off jet into the intake maniflold (which regualates nitrous pressure to the nipple on the fp regulator, pressure shuts the return valve and boosts fuel pressure to over 90psi in the rail for fuel enrichment, at the same time spraying a dry single nozzle into the intake boot. .059" jet is what I used and and gained over a second in the old lt1.. very slick setup. Im sure jet sizes may be altered to make it work on the return style ls1 cars.
Old Jan 5, 2006 | 01:34 AM
it hit harder than the 5177 kit in stock form, but im learning more on how to make the 5177 work better, with the help of Robert56.
pcm tune is next on the list. + my trans is going under the knife for firmer shifts and no more smoking the 2nd gear band. new band, pushrod and aftermarket servo is on the way.
I may delete the 2-3 accumilator also, but not sure yet. I also may send my verter back to Yank for inspection while we are there. fluid looks good and smells normal. but 1-2 slippage is def happening, especially cold. Is there known problems with the 4L60-E that I can ask about?
Old Jan 5, 2006 | 06:24 AM
95ttoplt1's Avatar
Hey Killer thanks alot, I am piecing together a 5176 from my wet purge kit, I am getting a 255lph walbro, will that be enough for the fuel side or will I still need a booster pump?
Old Jan 5, 2006 | 02:40 PM
Robert56's Avatar
Two things you can do to make the 5177 hit harder. Drop one of the redundant noids, then keep lines from noid to nozzles as short as possible. also, replacing "tee" with a "y" will help a slight bit. On the other hand, on my '97, I made a poor man's window switch by extending/adding a line from the noids to the tee, took a couple extra micro seconds to hit clylinders, but enough time to be able to floor that bad boy auto right outa the hole, with no problemos, cause would be around 3000rpm before spray was doing it's thing. Tuning these kits can be done in many ways.
Robert
Old Jan 5, 2006 | 03:45 PM
11 & 7 Second Clubs
I don't know what "kit" I have now, but I kept the 5177 line, replaced the 5177 noids with a set of NOS Part no. 16000 noids (250 shot) and have moved into the 40/44 jet size range.
