Anyone running Dry using Progressive?
Currently I have a 5177 split up for two different stages. I was planning on using one stage out of the hole with no jets, ~150rwhp, then delay/WS/progressively intorduce the second stage also sans jets. The more I think about it, if there are no issues, I might as well do both stages wired off the pro-control and slowly ramp it up. Using a dyno I can watch where the tq vs hp are and adjust the ramp rates accordingly.
So, Robert or anyone else do you see any issues with this?
Run down:
10# bottle
Dynotune heater
-4 Line
NX Filter (up front)
5177 split Robert style
Noid 1- to NOS Nozzles w/o jets
Noid 2- to koolrayz custom single inlet dual outlet centered on lid, jetless
Walbro in-tank pump
FMS 42# injectors
Speed Inc Rails -6 off the line to -8 inlet and crossover
TR-6 Plugs gapped accordingly
Tuning by me via HPT
Forged 347, 11+ cr, custom Nitrous cam by EDC, TH350 w/ 4000 stall and soon to be shredded Stock 10bolt!
So yeah you can do the progressive dry.
As a matter of fact Vince's setup was progressive dry and he made well into the 800+ rwhp are all dry.
Robert
I like your 1st idea better, hit it with the 150 shot(put the right jet in it with the better noids no running it with no jet) hopefully it will max out the MAF then progress the 2nd stage.
My set up is a hidden all dry 2 stage (125-75) with the FJO controller
AL, how are saying your going? You mention one BIG Noid, but then mention 2 stages?
Time to order up a round of Noids....now to decide from where!
Robert
Edit: Oh yea once you max maf out and have big enough injectors, you just keep upping the nitrous jet until your a/f falls where you want it. some have done this, but, imo, it's less than ideal for most of us. The easiest way to max it out is to hit it close with the spray.
And it doesnt freak the MAF out. Works just fine. I think if you had it too close to the maf it may freak it out...but so would a normal shot.
Run down:
10# bottle
Dynotune heater
-4 Line
Noid 2- to Noyzee custom single inlet dual outlet centered on lid, jetless
Walbro in-tank pump
FMS 42# injectors
You can see the spray go on and off and the car surge with it.
Might work if you faced the nossle away from the MAF but spraying that much faced away from the motor wouldnt be efficent.
How far away is your nossle? Which way do you have it aimed?
Mine is pretty close and it works great just hitting it 100% if it is close and you progress it it will freak the MAF out.
You guys are listening to too many old wives tales.
My brother and I have been using both the smaller and larger solenoids on our Street Bike Shootout bike. On a 175 progressive shot it runs 7.80's @ 186mph. I think the N.O.S. solenoids work fine...
now thats an interesting question
I dont think you would be able to do it that way. I think you may have to go to a wet kit. Have to think about that one.
If you could see the spray go off and on and the car surge with it...maybe something was wrong with the noid. Maybe it wasnt opening with each pulse. It would be tough to detect the car surging 14 times a second. So if it was surging in a noticable fashion it may have been due to another reason.
The system I tested it on was on a regular 5177 kit with the nozzles on either side of the intake lid. And it had no issues from 490 rwhp (NA) then spraying up to 750 rwhp all dry thru the controller. Ill see if I can find the graph. On mine I have a pretty long intake tube and dual filters out front. There is a long space for the nitrous to mix with the ambient air.
If you experianced some surging due to the MAF freaking out there are a few things you could do IMO. Change the direction the nozzle points in relation to the MAF, Increase the lenght or diameter of the line after the noid so the pulses have more time to recombine on thier way to the nozzle. Actually a good way to possibly do this would be go from the -3 line to a short -4 line and then back to -3 again and to the nozzle.
Another way to do this...especially if you have a 5177 kit split into dual stages...or just a dual stage dry....would be to run each stage at the same time ramping at the various rates. This will double the frequency, I believe, of the actual openings and closings. Since the contoller alternates between stages. In other words one stage comes on for its cycle then power goes to the other stage for its cycle.
You could also try to jack up the frequency a bit so the pulses are smaller but more frequent...this would smooth the flow as well. But Id ask the manufacturer of the noid what the max freq would be before doing that.
Another thing that may help would be to run lower pressure and larger jets. That MAY decrease some of the velocity of the pulses the MAF sees if its freaking it out.
Just a few ideas for you if you are certain you were having these problems due to the pulses freaking out the MAF. I have no idea if any will work But it may be worth a shot for you to utilize your controller in progressive modes.
