crazy cam question
Old Jan 12, 2006 | 11:50 PM
spanky_55amg's Avatar
Default crazy cam question...and it has to deal with n2o
g5x3, g5x4, or t rex???
and im only talking like a 150 with that.
and why that cam, b/c there are no x4 specs that i know of..........
Old Jan 13, 2006 | 02:35 AM
2000Hawk's Avatar
Magic Stick V3 from TSP has some awesome numbers on and off the juice.
-Joel
Old Jan 13, 2006 | 09:42 AM
Matt D's Avatar
Retired Street Racer
MS3. It is bigger than the x4 and will gain more than it on spray.
Old Jan 13, 2006 | 10:07 AM
yeah **** i ment to put that instead of the x3...it was late at night and trying to post on like three boards...hahaha
i dont suppose anyone knows the x4 specs b/c this is what i have
236 244 602 612 111+2 g5x4
236 242 603 609 113 ms3
Old Jan 13, 2006 | 10:20 AM
Matt D's Avatar
MS3 is 237/242 .603/.609 113+0
and the x4 is similar with 8 degrees split on the duration and lift. I don't want to give the numbers out, but you are close. The 113 LSA on the MS3 makes it better on spray.
Old Jan 18, 2006 | 01:50 AM
Chickcar's Avatar
would the magic stick be ok to install if the car is stock? And would it be the best choise on dry 150 shot also?
Old Jan 18, 2006 | 12:29 PM
Matt D's Avatar
I am running the MS3 and going to be spraying 150 dry. I will post on the results once the track opens.
Old Jan 18, 2006 | 01:29 PM
GM Muscle's Avatar
I love my MS3 and I think you would too. I think it will be the best daily driver cam out of all your choices. With a dry 150 and this cam you will deffinatly have to go with larger injectors and a fuel pump. When I put in my MS3 my 26.6 injectors maxxed out with just a little 35-45 dry shot. In full street trim the runs 10.60s@130-132 on a 150rwhp shot through 2.5" duals.
Old Jan 18, 2006 | 09:07 PM
Matt D's Avatar
I sold my NX wet kit and I am going with Nitro Dave's Halo Kit with the dry spray bar. I have 42lb FMS injectors, Walbro 340m in tank, Walbro 255 inline, and a Casper Fuel Pump Hotwire kit wired in to the in tank pump. I figure it should be enough for a 150 single stage dry shot.
Old Jan 19, 2006 | 06:24 AM
GM Muscle's Avatar
That should be more than enough fuel. My little Walbro 255 is supporting a 225 off the rails with a hotwire kit and voltage blaster.
Old Mar 24, 2006 | 04:49 AM
EXILE's Avatar
i like mine so far but always looking for something better
