SI capabilities on large shot discussion
383 had chimed in that 650ish is the limit torque-wise to keep everything together and that the progressive controller is the best way to keep things in check
also on top of that has anyone played with torque management?
just something else to try and keep these things alive with alot of power.
Had they used a very good tune and much higher octane to ENSURE there was 0 detonation they may have been just fine.
So the limit may not really be known. I dont thing that 700 rwhp is outof the question.
The thing is you have to classify terms like "limit" and "safe". One persons definition of whats safe may be that they could spray away and still make 100k miles. Mine is that I could spray away and make the motor live for a year...lol. If I sprayed to get 700 rwhp total on a stock bottom and I raced it for 1 yearbefore it **** the bed....Id be happy about that and consider that fun and practical. Hell...maybe even 6 months. Others would be heartbroken and be put ina bad financial spot. SO skew your "safe" limit to what applies to your situation...know what I mean
I think absoltuely safe is 550 tq and 550 hp. MId level safe that is taking a chance to me is 650/650. But I think if you had the ***** and were ontop of things...a bit more may be achieveble.
I think most people have big goals and different realities,so with that said on the average guys DD that visits the track infrequently street races infrequently,I think 650 is a sound livable #.
what do you think about meth or alcohol as a octane alternative on a "blower impaired"
vehicle?
Robert
Robert
I use edit but I have no clue how HP works.
Edit has a table with tq. reduction by gear,Id be interested to see what tuners
has for their tables.
let me know what you can find!!
Robert
does tuners have TM setup by gears?, you could set set torque at 450 or any mark that would be just above NA and pull extra timing in just 3rd and or 2nd and 3rd
Robert
possibly a 3rd stage that would be maxing out the maf or SD wet setups that would not just be a nitrous tune
even NA cars seem to run a tenth or two better when a degree or two is pulled in 3rd
