NX Bottle Opener Circuits
Old Jan 14, 2006 | 09:50 PM
GTOtoGO's Avatar
Default NX Bottle Opener Circuits
http://www.nitrousexpress.com/Instructions/opener.pdf
Can I run the wire, "Black wire to motor" to ground and run a single wire ("Red to motor")f rom bottle to switch? Anybody have another wire diagram that they used?
Thanks
Old Jan 14, 2006 | 11:37 PM
BadAssFast's Avatar
I don't think so...I think you need a DPDT switch center off and cross the outside poles with center posts as +/- DC out to opener...so when one side of the switch is depressed you feed + to make motor go one direction...when you reock the switch the other direction if they are crossed you turn motor in opposite direction...i'lledit with a picture.
Does this help...look at left side switch...
http://www.nitrousexpress.com/Instru...witchpanel.pdf
or
Old Jan 15, 2006 | 12:30 AM
GTOtoGO's Avatar
Yes,
I get it now,
Thanks
