New Solenoids?
Old Jan 15, 2006 | 01:40 PM
sickss228's Avatar
Default New Solenoids?
Hey guys I'm getting ready to hook my TNT F1 kit back up after I blew my motor, which I think was caused by a bad solenoid. My question is should I rebuild the TNT solenoids or buy new ones? I was looking around at NX and cold fusion both seem good but cold fusion has a lifetime warranty on theres what do would you guys do? Thanks for the help
Old Jan 15, 2006 | 01:50 PM
Matt@HSW's Avatar
Depends on what you are going to rebuild on the solenoid. If you re do the coil and the piston you'll be around $80, give or take. For a few dollars more you can get a new 3 port solenoid with a lifetime warranty on it:
LINK
Matt
Old Jan 15, 2006 | 02:47 PM
Justin@NitrousOutlet's Avatar
NX solenoids come with lifetime warrenty also.
Old Jan 15, 2006 | 04:19 PM
sickss228's Avatar
Thanks for the input anyone else?
Old Jan 15, 2006 | 04:35 PM
383LQ4SS's Avatar
I would atleast call TNT. See what they say. May be able to save you some money.
Are you sure it was a noid? What happend?
Old Jan 15, 2006 | 05:00 PM
NitrousDirect's Avatar
Cold Fusion certainly does offer a lifetime warranty and it's a high quality noid! We'd be happy to help you out
Old Jan 15, 2006 | 05:56 PM
227Hawk's Avatar
I'd talk to TNT about yours. My next choice would be Nitrous Direct for some
Cold Fusion solenoids.
Hawk
Old Jan 15, 2006 | 07:11 PM
sickss228's Avatar
Yeah I'm pretty sure the first pass it was dumping black smoke out of the pipes so I thought the nitrous solenoid wasn't opening. Cleaned and removed the debris (very small amount) from the filter inside the 'noid and made next pass didnt even get passed the 60' before white smoke started to pour out and the motor shut down. Number 8 piston was totally destroyed only the wristpin was in the bore still and it put a hole in the bottom of the block in the number eight bore right above the oil pan. Thats why I'm thinking I need to rebuild them what do you guys think?
Old Jan 15, 2006 | 09:14 PM
Nitro Dave's Nitrous Outlet's Avatar
I would contact David Or Sam at TNT. They have a good quality solenoid.. Send it to them for rebuild and checked.There is no sence in tying up the money in a new set of solenoids.
Dave
Old Jan 16, 2006 | 12:43 PM
sickss228's Avatar
Thanks Dave I'll do that
Old Jan 16, 2006 | 04:19 PM
Robert56's Avatar
This why annual maintance of noids is a goog idea, and cheaper. Or running a dry kit, sorry couldn't help it.
Robert
