Cool, New Products at Nitrous Outlet
Originally Posted by TwoFast4Lv
Tell me more about the L98/LT1 plate. Is it 58mm? No bars in it so easy to fix but that has always been the killer on them.
ALWAYS looking for a new toy
Will it support a 200 shot? how is distribution?
might make for a good second stage
Will it support a 200 shot? how is distribution?might make for a good second stage
This plate is desighned just like our LS1 plate.
Dave
Hey Dave, any update on the new site???? Just wondering cause I saw a few things I'm going to be purchasing....
Will the harnesses only work with your switch panels??? Reason i ask is because i see switch panels that will fit LS1 dashes but nothing specific for LT1. I might need to fashion one but I want to install the solenoids with your harness to keep everything clean and easy...
And I AM SOOOOOO BUYING your standalone 1 gallon cell for supplemental fuel.....
The dedicated is sweet
Dave
Whats comes with the LT1 plate kit, is it annodized like the LS1? Also what accessories would you recomend for a first time N2O user? Or should I just call when I make it back from the sand box?
The LT1 plate conversion comes with the billit plate,gasket,throttle extention bracket,hardware, and jetting from 50-200 HP.
The complete system will have the above pluss 30 hp solenoids,10lb bottle, all hardware,electrical and hoses.
I would suggest a window switch,bottle heater,purge,fuel pressure safety switch,nitrous pressure gauge,nhra fitting and blow down tube for a complete set up.
Dave
Dave
