Window switch?
Old Jan 17, 2006 | 06:23 PM
Silver moose's Avatar
Default Window switch?
DOes installing a window switch effect performance or would the car be faster spraying thru the shifts?The car has a a4 and if it will loose how many tenths if any
Old Jan 17, 2006 | 06:44 PM
Nitro Dave's Nitrous Outlet's Avatar
A window switch is just for safety. You can set it to shut off embetween shifts but you can also set it higher than shifts.This way if the tranny slips it shuts off the nitrous.
Dave
Old Jan 17, 2006 | 06:49 PM
so if my car shifts at 6500 and the window switch turned the spray off at 6400 or 6300 would i loose a tenth or nothing at all?
Old Jan 17, 2006 | 08:21 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Youwill not loose much, but if you want to spray thro the shift, just set the high side before the rev.limiter hits.
Ricky
