How are you guys routing your bottle opener/control wires from the center consol to.
The spare tire area on a 01 SS? BTW, I want to rout the bottle heater wire and control wire to the spare tire area also. I'm having a hard time feeding a hanger wire under the carpet. thanks in advance
Thanks for the reply joeyGC5, Anymore more methods out there? I cant believe only one person has done this. I guess I will just put a connector on the wires and run the plug over the carpet untill I figure out a better way or wait untill I hear of a better way to come along.
I did like MetallicaMatt... unscrewed everything: center console, side panels, rear panels, all of it. Then I peeled the carpet back a bit and ran my wires, which I already had wrapped up in wiring loom.
-somebody
-somebody
GOT IT! Just did it like joeyGC5 did it, disconnected the seat and ran the wires though, it was really easy since right under the seat there was a slit in the carpet already and the carpet is loose under the seat, I put a long piece of heat shrink over the wires and then put convoluted tubing over that just in case there is some unforeseen chaffing of the wires under the carpet. I should be able to fire this thing up with nitrous tomorrow. Thanks for everyones help!
