Nitrous backfires
Old Jan 30, 2006 | 04:23 PM
BBBBadSS's Avatar
Default Nitrous backfires
What causes nitrous backfires? Is it fuel puddling in intake, or is there more to it than that?
Old Jan 30, 2006 | 04:43 PM
NXJeremy's Avatar
There have been several long winded debates/arguments/etc. on this topic. Use the seach feature and you'll get plenty of info on it. This would be much better than kicking the proverbial dead horse, lol.
Old Jan 30, 2006 | 04:44 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Lugging the engine, over powering the engine components, and a few others. Mostly human error.
Ricky
Old Jan 30, 2006 | 07:54 PM
BBBBadSS's Avatar
How are some ways backfires can be prevented?
Old Jan 30, 2006 | 08:30 PM
The Sad's Avatar
Window switch for one.
Old Jan 30, 2006 | 08:42 PM
Robert56's Avatar
Tempting, but yes, search can be a best friend.
Robert
Old Jan 30, 2006 | 08:49 PM
z06pdq's Avatar
Robert
aw come on robert-you know you want to
Old Jan 30, 2006 | 10:08 PM
NXRICKY's Avatar
Well a window switch is a good one so to keep you in a safe rpm range low and high, also a fuel saftey switch to make sure your fuel pump is up to the task. Installing and operating your nitrous system to the mfg. specs. Nitrous filter to keep the trash from getting to the nitrous noid. Staying with the proper hp level for your appliction. 400hp on a stock engine just will not cut it, back fire and boom for sure.
upgrading your fuel system to the hp level you want to run plus some.
Ricky.
Old Jan 31, 2006 | 09:04 AM
BLOWNTRC5's Avatar
What about a sudden close of the throttle? Could the lower the velocity enough to enable a back fire? I run a dry first stage, and am considering a wet second. I'm using a FJO dual stage window switch, and all of the normal safty stuff.
Thanks,
Doug
