window switch tach input...
Old Feb 3, 2006 | 09:53 PM
00Z-28-LT1's Avatar
Default window switch tach input...
1996 LT1 Z-28 M6. did a search and found only LS1 info. i need to find out what wire it is on the computer to run the tach input part of the window switch off of. it is a MSD window switch. thanks...
Old Feb 3, 2006 | 10:37 PM
jldak318's Avatar
its pin 13 on the red connector to the pcm, its a white wire. i just hooked mine up last week and it works great.
Old Feb 4, 2006 | 10:39 PM
00Z-28-LT1's Avatar
how do you count pins or are they labled?
Old Feb 5, 2006 | 07:11 AM
jldak318's Avatar
labeled on the back of the plug, take the plastic covering off the plug and it will say it. there should only be one white wire on the red plug and thats the one u need.
Old Feb 6, 2006 | 11:16 PM
00Z-28-LT1's Avatar
thanks
