Where to run main N2O line?
Old Feb 4, 2006 | 07:25 AM
ken02ws6's Avatar
Default Where to run main N2O line?
Getting through my nitrous install and still havn't ran my main feed line yet. I have the bottle mounted in the spare tire area and was wondering where the best place to run the n2o line would be? I figure go down through the rubber grommet but not sure where to go from there? GMHTP drilled holes and zipped tied the line along the car but not sure about drilling the bottom of my car like that. Any ideas/pics appreciated.
Old Feb 4, 2006 | 07:47 AM
next's Avatar
I'd venture to say that a lot of folks just run it inside the car under the carpet. I guess there is a little extra safety by going outside the car, but the reality is you still have the bottle and end of the line in your car since you don't have a trunk. I don't see braided lines having a high failure rate and inside the car is NHRA legal. Just my .02.
Old Feb 4, 2006 | 08:34 AM
ken02ws6's Avatar
Thanks!!!! That will save me alot of time for sure
Old Feb 4, 2006 | 09:37 AM
next's Avatar
Glad it was a help. If you run along the passenger side you can use the firewall grommet behind the glovebox/PCM to get to the line to the engine bay.
Old Feb 4, 2006 | 09:41 AM
Hennytime's Avatar
i put mine through the gromet behind the ecu and under the passenger door sill. getting the ecu out is much easier than getting it back in, good luck
Old Feb 4, 2006 | 09:50 AM
ken02ws6's Avatar
I have already run some wires through the grommet behind the ECU, wish I had to run the line as well. At least I know a few tricks this time
Thanks guys
Old Feb 5, 2006 | 02:38 PM
gollum's Avatar
Run it along fuel line with nylon ties. Veryeasy!
