what will i run?
Old Feb 5, 2006 | 12:12 PM
Hark_Z's Avatar
Default what will i run?
My car: LT1, 3.73's, intake, exhaust, tune. I have no suspension mods, tires are decent all season, BFG KDWS.
Getting a ZEX Wet Kit 75/100/125
1)What times do you think I'll be running?
2)Also what do you guys think about ZEX?
3)Do I need anything else besides new spark plugs and a tune? Bigger injectors?
Help me out guys, I'm excited!
Old Feb 5, 2006 | 12:35 PM
chris77's Avatar
times is kind of hard to answer alot has to do with it like:is your car auto or stick, how good you drive, tires, what shot you run but if i had to guess with an auto on a 100 shot you sould be good for low 13's.
since you got a wet kit you dont need bigger injectors but you should buy some NGK TR6's, a 255 fule pump and a tune.
Old Feb 5, 2006 | 12:49 PM
Hark_Z's Avatar
Thanks for the input, I'll check it out. I also realize there are a lot of deals floating around on torque convertors like Yank and I realize they will make a world of a diff too, would you recommend about a 3200?
Old Feb 5, 2006 | 02:10 PM
sleeperstyle's Avatar
zex kit= rated at the flywheel. so 125 shot is ~ 100rwhp from what i've heard. if you spray out of the hole and dead hook you might get 1 second out of it but probably a little less.
