Idea on prices
Old Feb 10, 2006 | 04:44 PM
Shooter9's Avatar
Default Idea on prices
What prices am I looking at to pick up a 100 shot nittrous kit.
Dry or wet ? It is for a stock car V8.
I have been told that dry is better for stock.
Dont know myself its all new to me, but fixing to learn.
Thanks for the info.
Old Feb 10, 2006 | 05:04 PM
brad8266's Avatar
dry is easy and cheaper. I prefer wet kits personally. With dry you need to change injectors with larger shots, which is just another expense. A kit will run about 500-600$$ with a heater and the few other items you will want.
Old Feb 10, 2006 | 06:05 PM
Matt@HSW's Avatar
What do you plan down the road mod wise? A dry kit can be had for less then a wet kit, but depending on what you want to do mod wise one might be a better choice then the other. If you are planning on just a few bolt ons a dry kit might be the ticket. Cam + bolt ons and upping the shot to a 150 and the wet kit might be a better choice, as you might not run into having to upgrade to a larger set of fuel injectors.
Matt
