timing tuner/electronic tps help
Old Feb 12, 2006 | 11:53 AM
Threesixes's Avatar
Default timing tuner/electronic tps help
Anyone know how to hook up the timing tuner in conjuction with Harris Speed Works elctronic tps switch in a N20 application? The timing tuner instructions wants a 12v signal from the tps(wot) switch into the timing tuner but the electronic tps sends a ground. At this point all I have thought of is using the tps to complete my ground on the nitrous arming switch, but then it will only light up on WOT. Any ideas?
Old Feb 12, 2006 | 12:10 PM
Matt@HSW's Avatar
You can use a second realy to go from the ground to a 12v. I'll draw somithing up now. Also responding to your pm.
Thanks,
Matt
Old Feb 12, 2006 | 01:14 PM
Threesixes's Avatar
Thanks Matt, for the Diagram! My brain was about to blow a fuse. It seems to me, when it comes to service, you always go above and beyond most. I'm not sure how many others would have drawn up and sent me a diagram within minutes of posting my question. It was a good diagram too. Thanks again.
Josh
