Here It Is Gto Guys !!!
For the last few months we have been building two new dry kits for you GTO guys.
The first is our Halo dry system. This system places a spray bar in your stock air box. This desighn will better attomize the mixture of nitrous into your air stream. This system will give a hidden install to keep your compition scratching there head.
You can find this system on this months Nitrous specials.
This is the stock GTO Air Box. With the concelled system.
Once removing the top. You will see our custom one of a kind Halo spray bar.
The jet will go in the Halo fitting where the line screws on. Notice the fitting comes through the filter.
Your solenoid will mount inside the box with two push pins or nuts and bolts.
You can mount the relay right inside the box. Then all you need to do is finish the wiring. Make iit look nice with some wire loom and you are ready to go.
The second desighn we are building is for you guys running the after market cold air kits with cone style filters. This desighn will give you a much cleaner concelled intsall that the current methods. WE will hopefully be releasing pics sometime real soon.
So what do you guys think?
Dave
This is our test unit.
During this build we tried several different desighns to come up with something that was very user friendly. We ended up with something completly different from the original desighn.
This desighn will work by placing the unit inside the air filter. The fitting will push through the filter and the nitrous line will screw on to this fitting. This is also where your nitrous jet will go. Rotate the filter down and the unit can be tucked away and hidden.
The purpose of this unit is to keep from placeing the straight blow through nozzle in the end of the air filter. This should take the posibility of freezing the maff away.
This system will work on the Truck and GTO cone style filters. For the guys running the large oval filters all I need is a filter and we will have one for them also.
This is the test unit. We are currently building the units to ship.
What do you think.
Dave
Dave
