FJO questions
Old Feb 14, 2006 | 10:19 PM
02Vortech's Avatar
Default FJO questions
Im probably gonna get the two stage mini controller from FJO and i was wondering-
i dont have a two stage set-up should it work fine just dont make a second stage during programming?
if i do go to a two stage set-up will it be very easy to program/wire it into the system?-
It appears to make the wiring of the nitrous system a breeze so how long should the rewiring take + !!!!!!
which wiring diagram would i use in the instruction manual- it looks like the first one but would the 1st stage out put be the power to the solenoids?, then just ground the noids somewhere else?
Old Feb 14, 2006 | 10:21 PM
Nitro Dave's Nitrous Outlet's Avatar
Correct you would just not use the second stage. If you decide to use it later you can just add it then.
Dave
Old Feb 14, 2006 | 11:00 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
The FJO controller controlls the grounds to the Noids.. Give a shout when you have the system, I can send you a diagram with the connections. Now that second stage wire just hanging around you can use that to controll a shift lite..
Ricky
Old Feb 15, 2006 | 07:54 AM
redbullapril23's Avatar
so i could use the 2nd stage wiring to activate a retard box.. and just have the RPM windows the exact same?
i just ordered my FJO last week from Dave.
Old Feb 15, 2006 | 07:56 AM
also does the 2 stage fjo contoller have 1st and 2nd lock out or just first?
thanks Ricky
your friend
Sean
Old Feb 15, 2006 | 08:51 AM
NXRICKY's Avatar
I will need to know who's retard box.
Ricky
thanks Ricky
your friend
Sean
First, only.
Ricky
Old Feb 15, 2006 | 09:05 AM
got ya sounds good.
the retard box will be a future edition for now ill just run the retarded timin.
i was think the MSD wheel retard.
btw i have a 1996 lt1 vette
