Who makes a good N20 controller?
1. Decide what exactly you want to control and what equipment you already have (like window switch/WOT switch/fuel pressure switch/things I have forgotten) to help determine what you need.
2 Call some of the vendors and get some ideas exactly what their controllers can do and what is needed with them.
3 Ask advive on the forums after you have determined what your needs are.
Right now with what you are asking it's like going to a fastfood place saying you want something to eat to the person at the counter. More info is needed on what you already have and what you are looking for and if you really need one depending on size of the shot.
Good luck!
www.nitrodaves.com
206 bucks! You CAN NOT BEAT THIS CONTROLLER
This is MY stage 1 on my 03 cobra (6 speed)!...rpm based progressive, you can also do time based progressive!
With the FJO unit, you can do EVERYTHING you need.
Window Switch...chec
WOT...check
rpm based progressive...check
1st gear lockout...check
time based progressive...check
2 seperate stages, one can be time, one progressive, doesn't matter...check
"trigger" for frps....check
You can use the trigger for a BUNCH of different things. If you have a WBC that has nitrous outputs, you can use the "trigger" on the FJO to work with it, so that it only sprays in certain Air/Fuel ratios.
Like I said, you can NOT beat this, especailly for $206!!!!
www.nitrodaves.com
WOT...check
The FJO unit looks great and has a good following as well as all the features you would need. Price is also great, BUT it does need a laptop to make adjustments when at the track. Not a big deal if you are monitoring your runs or even running something like LS1Edit, but may enter into more $$$ if you need to get one just to use the FJO to its maximum.
The HSW Edge has all the features you are looking for and falls into the price range you set. The big plus is no computer needed, so it is adjustable at the track without a laptop.
Both units (and other complete units) can do what you want with ease and going with either unit will be cheaper then buying seperate items (TPS/Window switch/controller), so it comes down to wanting to have a laptop with you at the track or not. Again this may not even be a factor if you are already carrying one.
Hope this helps... I am sure others have even more info on other units.
Thanks,
Matt
btw Harris can u shoot me a pm on how much the W/B connection is?
and do we need the ignition adapter for the window switch option?
well now ive got a perfectly good, pretty new Timing Tuner for sale if anyone wants first stab at it, before it goes in the parts for sale section.
No adapter is needed for the LSX platform for the window switch.
