Discussion: Nitrous nozzle design and is it important?
Robert
If you show real proof I will certainly accept it. But it should not leave anything to chance or have missing info.
That fine if all the big guys run straight nozzles. But they all run straight nozzles by different manufacturers. And they all work just fine. Same for the people who use 90s. Youll here some racers swear by ProFlow, some still stick with NOS some will have nothing but NX, etc. So which one is best and why? Why is there CLEARLY NO SINGLE NOZZLE that rises to the top or that has been proven to be the best.
You guys or manufacturers that want to prove a nozzle is better??
I would even say test at more than one rpm to see if the theory that one nozzles atomization may be better...I believe if one atomizes better it may be more apparent at lower rpm. So maybe test at 3000 rpm and at 5500 rpm.
One of the companies that makes the claim of having the best nozzle should prove it IMO.
The point is this: Buy a QUALITY nozzle that you like and works in your setup and stick with it! Tune it up and run it. Then spend more time on chassis setup and other areas. Dont start swapping nozzles and setups looking for some holy grail ...because its not there.
Hopefully members here learn things and see through the hype enough to make their own judgements.
Robert
Again....engine dyno with brake, hold engine at 4500 rpm, spray for 10 seconds, check AF, check nitrous and fuel flow rate, recalibrate jetting so flow rates are the same for each nozzle, and measure the TQ output over that 10 seconds. Check peaks if any as well as avg TQ output over that 10 seconds.
If you're racing, nozzle design is huge. The bottom-out style nozzles are far superior to 90* nozzles. FAR superior. All of the good nozzles are basically copies of the other. The NOS 'B' Nozzle, the Nitrous Pro-Flow 'V-Force' Nozzle, and the Speedtech 'Tech 1' Nozzle are basically the same. They work off of the same principles, and are the best nozzles available for multiple systems working at once.
On the lsx platform, running the throttle body in the front of manifold, and having a below the runners plenum, I think mixture/atomization plays a bigger role than you guys realize, on a street/strip car. there are many wuss's running smaller shots that will still benifit from advanced engineering. Man you guys are a tuff bunch, that's for sure. Dyno sheets are on the way for all to pick apart. Maybe, we could do this (testing) again and have a rep from each company on hand, so no one can claim invalid/unfair testing? Then we head to the strip for some real world thrashing.
Robert
And for the record I have never said NX's nozzle or TNTs or any other nozzles where better than the next. I have always said..."get a good nozzle" and thats the extent of that. I dont care what NX has claimed and just as in the past i dont care what TNT claimed either. It doesnt affect the outcome and actual facts that have always presented itself to me. I am only interested in hard data that is repeatable.
I have used about 75% of the nozzles on the market at one time or another on like systems. And not one has ever performed susbstantially better than the next that made me sit back and say..WOW...I will only run these nozzles from now on. I would expect to see a pattern develop by now...but none exists. If you think so....SHOW ME!
If you tested to a close enough degree to actually uncover the differences...you would find them to be minute and negligable. And as Tony said....2% difference when your running a 150 shot does not amount to anything usable or practical...especially when your kit can be jetted to 300 hp.
As far as running huge shots...to me thats more a function of nozzle behavior and patterns at and near maximum flow levels..which could be quite different at lower flow levels. That may be something worth investigating. Or if you are resticted by class rules to a maximum jet size another 2% could mean something. But again...for the avg 99% of us users....all the good quality nozzles will get the job done. And for the ones that may benifit from squeezing every last drop and might be concerned about effeciency...they should really do thier own testing to back up the claims because no testing has been done to date that is real or convincing.
Robert...Im not an NX rep and I think thier nozzles are as good as the next guys quality nozzle. I am a Nitro Dave rep...he carries several brands. I could care less about claims anyone makes including our products. I just want facts.
Robert
A bottom out nozzle is better than a 90* like Ben already said. And a 90* without the notch in the the nozzle for fuel like the speedtech one is junk. Our nozzles are designed to create a low pressure area and the nitrous pulls the fuel out dependent on pressure. Everyone already understands pressure differental.
Also like he said for most guys on this board that will never spray moe than 200 it nozzle probably doesnt matter, but I have been told by many customers and well know engine builders just swapping out other brand nozzles and putting ours in keeping the same jets, ours made more power.
B.E.S has done dyno testing like this and used 90* nozzles and took out Pro Flow nozzles and put our speedtech nozzles in. Call them and ask them and see what they say.
But im not on here to argue about our product our anyone elses. Anyone that has ran our stuff or had a friend run it knows its the best. And thats why every big engine builder sends his manafolds to use to get plumbed ex. Sonny's, BES, Bennett, Shaffroff, Buck , Conrad, there are many more.
And our records prove that they are the best.
What other nitrous car does you know that has went 187 in the eighth. And consumers can still buy the same parts he has.
There are also numerous time people have called and said that they were burning pistons up or couldnt get there car to run on more than 1 or 2 and we fix what they had just changing the nozzles and and a 3rd stage and it goes down the track faster and on more stages than ever.
Also to the LT1 guy that posted earlier, no single nozzle in front of the throttle body will fix the distribution problems in the manafold. Thats a manafold problem not nozzle problem, but a fogger would fix it.
I definately agree on a 90 vs a straight. Thats a major design difference.
And on the people burning pistons on high HP tune ups and fixing it with a nozzle/setuop change.....that could be problematic characteristic of that nozzle at very high flow rates. It may not exist at slightly less flow rates on that nozzle.
Thats why claiming that one nozzle makes 3% more power at 200 hp is so incomplete. I would like to see real tests at low flow rates, very high flow rates and in between. You may uncover real problems induced near maximum flow...or even minimum flows. These would be areas that atomization may go right in the crapper and it would show the nozzles "effective range". I think most nozzles that operate within thier effective range will perform very close to one another. One nozzle may have a broader range than the next. That info would be nice to know as well.
But just sheer claims that one nozzle will make more on a 150 shot than the next is almost pointless IMO.
