Set Shift Points (A4) ; Extended
What is causing this and is there a way to bring the points back down?
I don't see any reason to shift at such a high RPM on a stock internal motor.
-Kyle
your line pressure runs up with sensed load, but bleed-
downs are what they are and get slower, the higher the
pressure was. So you need to put in some "windage" for
all this, just like you put in some enrichment.
If you have a "Tow/Haul" button, this is where I'd use it.
Program the Performance table for an earlier shift MPH
and a couple of hundred lower WOT RPM.
Of course if your window switch cut the spray far enough
before shifting then you might get by with one set of
settings.
No worries bout a window switch. Sprayin thru the shifts.
Which line pressure tables? I think I'll do like you said and set of the tow/haul for 'n2o' usage.
Thanks Jimmy.
