Question TNT Power Ring
Old Feb 22, 2006 | 05:15 PM
TINKRD's Avatar
Default Question TNT Power Ring
Should I rotate it so that it doesnt spray over the blade?
Its pretty close to the blade when its WOT. I never noticed it so much w/ the stock TB. I guess since the 90 is bigger it comes closer to the nozzles.
Old Feb 22, 2006 | 10:32 PM
TINKRD's Avatar
:bump:
Old Feb 23, 2006 | 07:56 AM
BAKNBLK's Avatar
I think it's supposed to work that way. If the nozzle was a little higher or lower it would hit the top and bottom of the throttle blade and not cover as much area as spraying straight at the blade.
