Direct Port 4 noids or 2
Old Feb 22, 2006 | 11:59 PM
Jimmy P's Avatar
Default Direct Port 4 noids or 2
I am considering buying a direct port system through Nitrous Dave. I am thinking of the 4 noid system, with the fuel rail upgrade. The most I would spray is 200 or so. Would a four solonoid kit hit harder than a two solonoid kit? Someone that I know had a 2 noid system with hard lines, then switched to a 4 noid system with braided lines, same shot, and he was saying it would hit a lot harder. So money not being an issue, should I just go ahead and get the 4 solonoid setup?
Is the fuel rail upgrade worth anything other than eye candy? I like how it looks, but if the stock ones work fine then no reason to change them, right?
Thanks for any responses.
Jimmy
Old Feb 23, 2006 | 12:27 AM
383LQ4SS's Avatar
I bet a 4 noid setup would probablly hit a bit harder due to the routing of the fuel and nitrous. it will generally be a shorter route to the nozzles through a 4 noid setup and the lines after the noids will fill faster with 4 orifices VS 2. The reult would be full flow through the jets quicker.
Old Feb 23, 2006 | 12:45 AM
Robert56's Avatar
I think I agree with, Al. did I say that out loud?
Robert
Old Feb 23, 2006 | 10:15 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Do a 4 noid with hard lines.. for that real hard hit.
Ricky
