probs w/ a dry kit????
i was told by MTI that ls1's were notorious for not liking dry kits. they told me that they wouldn't even install them on customers cars on request.
well, mine was already on that car at this time when i heard this and didn't have any problems so i blew it off. it was just 100 shot w/ all the precautions: colder plugs, tuned, good bottle pressure. ect. DAMN, if it wasn't a week later that my whole motor was trashed at hrp. im still not sure what happened. i heard a pop and the car shut off at 1000ft. two rods through the block. it was bad. can yall explain what could of possibly happened? the motor wasn't burning oil. it hadn't been abused, and kit was only on for about two months (3 full bottles). from what i hear of other people sprayin of stock motors, i didn't think that my 100 would of torn the motor up that quick. obviously i was wrong. have you guys experianced the same issues w/ dry kits???
Originally Posted by dirty2kTA
a4, vig 3200, decent cam, full exhuast and tuned for everything even the gas.
Robert
2000 car.. i put 28lb gm injectors it before the tune
Robert
What about fuel pump...man I never had any idea how quickly a stock fuel system gets maxed - not to mention stock pump alone on an FBody affects this stuff. In general, the more info you can put out there the better the chances of getting an explaination.
Edited: What he said^^^^
the fuel pump was stock. new fuel filter. the car made 380rwhp on motor. there wasn't a wide band on it, they just took enough timing out to satisfy a 100hp shot. like i said i was on the third bottle when it went, which could indicate that something let go. other than that the car was fine, it never detenated or acted funny it was very smooth on the gas until then. it was at about 5500rmp when it let go.
number 5 piston was turned 45 degrees inside the cylinder.. i had never seen something like that in person. nonetheless it was an expensive image. lol
the crank took a beating from everything coming apart. 5 & 6 rods were completely demolished, the biggest peice was about 3 inches. the pistons where ok other than where the broken rods hit them. if the motor is running consistantly lean then you more than likely will crack a piston i have heard. It looks as though the rod turned piston 5 at the 45 degree angle in the cylinder as it snapped. the was cam chipped and bent where a rod hit it. the vavles on 5 and 6 were bent. so pretty much nothing was even close to salvageable.
im a sr in highschool and pay for the car myself. wish i was parent sponsered but im not lol. i barrowed a stock motor from friend and put it back together w/ just cam. im going to save up and hopefully in july LME will be building me a motor that will handle more than a 100 kit before i got off to school....
I don't think that the factory F-Body fuel pump will pump enough fuel continuously to support 480 rwhp, and I'm pretty sure that your injectors were probably close if not completely maxed out too. I wouldn't have even chanced 100 shot on top of 380 rwhp on motor without upgrading the fuel pump and injectors. It could have been something else, but more than likely the motor went really lean on the spray.
dont yall think i was really making 480 to the wheels on dry kit.. i figured it being dry that i would be 460 roughly. aren't wet kits more efficient when it comes to make the numbers...
it was a .52 pill. it should of been exactly a hundred.
