Why not a progressive controller single stage?
I guess my point being that the cost of a nice 100-500 Direct Port setup would be as cheap or cheaper than buying 2 or three kits ... tuning costs would also be cheaper, wouldn't they? And wouldn't there be less chance for failure and destroying your motor?
Maybe it's the danger of an injector failing???
Having two kits also allows you to spray different amounts of nitrous. ex. If you are going to race a ricer you might only need a 75 shot vs. if you had a race setup with another f-body you might want to spray 150 vs. if you had a race with a track only car you could spray both kits and end up with a 225 shot
Another reason is if you setup one stage as dry you can actually tune the car to go into a "nitrous tune" when you spray the first stage so it will pull timing, add fuel and things like that.
Those are just a few things I thought of off the top of my head I'm sure someone else will have some more input.
Trust me I would love to have a DP but the funds where not there for me to pay out one big lump sum.
and of corse that bling thing, but back then it was called Ego. lol
With the new controllers on the market people are realising the potential to have big power, controll that power, and with just a simple clean install.
Ricky
So if you want one good stage and have it progressievely controled....nothing wrong with that at all.
Maybe this will make sense ... maybe it won't: I think this type setup will be better/safer because at 2,500 rpm, I can start to spray about 75 (instead of waiting 'til 3,000 to spray more all-at-once) and up-the-spray through the rpm range so the full spray (maybe 200-250) will be at the highest rpm before shifting gears. I believe it will be a lot easier on the powertrain and internals and provide a nice, steady, increasing pull ... soas not to break momentum of the forward movement of the car ... with little room for driver error ... as opposed to other type setups.
Anybody think this makse sense? Or, is this not the desired outcome one would reasonably want to achieve with a nitrous setup?
