msd digital w/s help
Old Feb 26, 2006 | 09:01 PM
Mach1killerls1's Avatar
Default msd digital w/s help
ok went to install it today and as i was reading the wireing diagram i found myself confused in the fact i know the white wire goes to the pcm on the 35 pin and i heard i could run the red to the arm switch and i'm guessing i can put the black wire to a good ground or the battery. but the yellow and grey im a little confused as to where the run imean the yellow also says ground now am i supose to ground that to a chasis ground or to the battery or to the relay ground for the n20 kit and they grey i have no idea where it goes. can someone please help me ?
Old Feb 26, 2006 | 09:09 PM
code4's Avatar
see if this helps you: http://www.nitrousexpress.com/Pages/FPSS_diagram.htm
Old Feb 26, 2006 | 09:25 PM
helps a bit but where does the grey wire go i think that was a diagram of the msd w/s but i have the digital w/s
Old Feb 26, 2006 | 10:08 PM
White Fire'99's Avatar
grey isn't used
Old Feb 28, 2006 | 03:59 PM
ok im still a little fuzzy on the whole setup but heres how i have mine hooked up from the diagram that nos sent with the kit.from the other diagram code4 sent i can't understand where to put the wire going from the fpss to the silinoid goes. can anyonetell me where the wires get connected from this diagram.
Old Feb 28, 2006 | 05:13 PM
did you hook it up like the NX one or the NOS one?
not sure i follow what you mean.
Old Feb 28, 2006 | 05:50 PM
ok found some info on gmht's web sight under their supernatural t/a and now i completely understand that the yellow wire has to connect to the two grounds comeing off the silinoids and the rason they original post by code confused me was because i only saw 1 ground and one nitrous silinoid. but i get it the white goes to tach, black to any good ground, red to the battery or the fuse panel, and yellow to the two grounds off the silinoids and the grey i don't need. please correct me if i'm wrong.
p.s would i be better off conecting th power to the fuse box or shoul i tie it in with the power wire to the nos kit off the arm switch
