BMN controller..how does it lock out 1st gear of 6-spd?
Old 02-27-2006 | 08:45 AM
danf1000's Avatar
Default BMN controller..how does it lock out 1st gear of 6-spd?
anybody used the bmn nitrous controller?? it has an option for a first gear lockout so that you can avoid the overpowered rear tires during launch.
my question is how does it do this for a 6-spd?? it would make sense that the car's computer for an automatic would provide a signal of when to shift to 2nd, and the controller might be able to read this as the controller is fairly sophisticated and is programmed with a laptop. but where would the controller get a signal if manual trans??
Old 02-27-2006 | 08:47 AM
danf1000's Avatar
i think i found it, uses a dip in the tach signal, like when second is engaged...
Old 02-27-2006 | 09:43 AM
iamsickofitall's Avatar
i believe you are right - it sees the dip in rpms
Old 02-27-2006 | 10:04 AM
Nitro Dave's Nitrous Outlet's Avatar
Correct. It reads RPM. When the RPM drops for teh gear shift it counts that as a gear change.
If you are looking for one we have them on sale right now for 99.99.
Dave
