Do I Need More Fuel Pressure??/
Matt
But on to my point, you'd think that if the stock pump can handle almost 600 horse to the wheels, that the racetronix would handle a lot more than it does, just my opinion though.
To the person that started the thread, I would double-check the FP gauge. It sounds like the readings you are getting are not accurate.
Matt
But on to my point, you'd think that if the stock pump can handle almost 600 horse to the wheels, that the racetronix would handle a lot more than it does, just my opinion though.Robert
But on to my point, you'd think that if the stock pump can handle almost 600 horse to the wheels, that the racetronix would handle a lot more than it does, just my opinion though.570 with the stock pump??? LOL...your crazy man!
Thats the most I ever heard of. It must have been giving every last drop.
Anyways....the limits we throw around here...like 475-500 on the stock pump are with a margin of safety in mind. Not to mention not many are willing to actually find the limit. Same goes for the Racetronix and Walbros. I have used a Walbro/hotwire kit/Caspers voltage balster for 725-750 rwhp about three or four times without inceident. The pressure drop on spray is usually about 5 psi at that HP. Not perfect...but there is still room. And AF stays rock solid. Including one pull that was about 740 rwhp all dry through the injectors. AF was rock solid.
Matt
And the racetronix handled both stages for the few seconds it took to make the dyno pull, a/f was at 10.1/1 on both kits and then started to lean out a little at the end of the pull when gettin close to 7000 rpm and went to like 11.0/1, but I figured it was just cuz I was gettin up in the rpms, but I guess it just can't keep up the fuel, cuz when I went to the track, it handled it for first gear and that was about it, right after hittin second, she burnt up a plug and I let right off when I heard it start to break up. My laptop had broke, so I had no datalogging to look at, but she definately went lean, i'm sure the racetronix didn't like 713rwhp (through a turbo 400 no less) under load, hehe!
So that is why I need a standalone!
)! I could definately tell the difference though, cuz I had always been told that the tnt kits run real rich, but when I was hittin the 100 shot with the stock pump, o2's stayed the same as on motor, maybe slightly richer, like 920's/930's instead of 900's, but when I put the racetronix pump in, no changes to tune, she started goin way rich, but motor tune was perfect at 12.8-13.0/1! But from what i've heard from all the guys sprayin 300+ hp, you want the a/f to be around 10.1/1 area, so that's fine. On the first stage tnt 200 alone, it drops below 10.0/1, but when I added the second stage dry, she went to 10.1/1 and then like I said, just started to come up a little toward the higher rpms (which I think the pump was starting not to be able to keep up). Once I get the standalone, i'm gonna have to grab a wideband so I can keep an eye on it and see where's it's at, cuz I am scared to put the car back on a dyno, last time I took out second gear in the turbo 400 cuz I shook the tires on both stages.The other funny thing, I think if I put the 100 shot back in there now, that I wouldn't run as good as I did when I had the stock pump in, unless I started messing with the fuel jets to lean it out some, cuz I went 10.20's @ 134.xx on the 100 shot with stock pump, and when I put the 150's in with the racetronix and how rich it runs now, I only gained 2 mph and went 9.95 @ 136.xx.
By the way, what a/f do you recommend for a 200 - 300 shot, am I running it way too rich at 10.1/1, is there power left on the table making it leaner w/o being dangerous?
Robert
Robert
When I used to run a 300 shot all dry for about 715 total I could get away with 100 octane unleaded and it seemed to like the AF a lil higher...maybe 11.8 or so.
As far as on the dyno and at the track..I alwasy just used the dyno to get close. The made small changes at the track to see what worked.
