Do I Need More Fuel Pressure??/
The Problem I Have Is Myfuel Pressure Runs At 54 Psi At Idle. But Whwn I Hit The Nitrous The Fuel Pressure Drops To About 25 Psi. Is This Normal Or Is This A Big Proble?
Thanks For Any Help
Matt
There is a solution. Matt helped me noodle out my issues.
Hawk
On a serious note i would be looking at a Racetronix Pump.
Hawk
To your thread...From my experiences, i'd say with a six speed and a Racetronix you'll be good. If you are using an AC Delco fuel filter and it's installed properly probably not the issue. Running out of pump may be. Even a Walboro 255, essentially the same pump with a relay and high current supply line (aka Hot Wire kit) would be an improvement. I've heard 650 rwhp on a Racetronix...i believe i maxed mine out on n20 at 585 rwhp with an AT/3600 stall/4.11...the math will give an equiv 6 speed anothe 100 rwhp or so compared to my car.
Macon i'm watching you! And that can't be a good thing.
Taking it to P.M.
Hawk
LOL.
To the thread owners...this is a great example of a Cold Fusion man and NX man who get along just fine...see it all good when we are having fun. The advice is real. The jokes are ...well uh a breath of fresh air.
Matt
Matt
Now off to the BASEMENT for me.
Hawk
The BAP can up voltage to around 17 volts I believe. They also work as a voltage regulator too so it compensates for voltage fluctuations in the electrical system. As for negative effects on a fuel pump being used with a BAP I don't think you will see any, only positive results.
Matt
Matt
Thanks
What nitrous system are you using? What jets? Where are you measuring the fuel pressure at, and are you sure the gauge is accurate? What exactly were the air/fuel numbers before and after the jet change?
Sorry for all of the questions, I'm just wanting some more information to try help figure it out.
Macon- No problem, just here to help. It seems like the majority of the time when people post questions about fuel issues everyone just recommends changing to a bigger pump instead of trying to figure out what is actually causing the issues. I have seen an F-body put down over 600rwhp with the stock pump and with out a hot wire kit or boost-a-pump. While I highly do not recommend trying to do the same, I also don't believe that people should run out and upgrade the pump just because they are having issues with either the fuel system or with not putting down the numbers that a car should. Ok, I'm off the soap box now
No problem on the questions, i know you need more info to help me figure this out.
Thanks
