NEWB to Nitrous
Old Mar 4, 2006 | 09:29 AM
FungusMungus05's Avatar
Question NEWB to Nitrous
My car sits in the shop getting a TNT 150 shot. I had a couple of questions. If there is a thread about this please redirect me to it. Those of you who spray out of the hole, are you spraying before your 60ft? How long do you spray for?
Old Mar 4, 2006 | 10:28 AM
cyipher's Avatar
most dont spray outta the hole, they wait untill their window switch turns on (3000 rpm -+ 500 rpm) or wait untill second gear.
Old Mar 4, 2006 | 10:51 AM
1MEANGTO's Avatar
I spray out of the hpole never had a problem. I let the microswitch do all the work. I don't use a window switch.
Old Mar 4, 2006 | 11:40 AM
GM Muscle's Avatar
It really depends on your track conditions, suspension, and tires. More than likley you will have to delay the hit out of the hole. Like mentioned above, you can use your window switch to do that or just do it manually with the master arm switch. You should be able to spray before the top of the 60' though.
