What do I need to do??
Old Mar 7, 2006 | 10:20 PM
BADBOYZ28's Avatar
Default What do I need to do??
I want to know what I need to set my timing at for a 200 shot wet with a TNT F2!! Right now my timing's at 28-29 degree's or so. Also where does my a/f have to be at to run this kinda shot. I have 42lbs injectors and a Racetronix p&p fuel pump along with mods in my sig.!! Also any other suggestions as far as what kind of octane to run(using 93 right now) and tunning suggestions would greatly be appreciated!!
Old Mar 8, 2006 | 11:35 AM
Somebody09's Avatar
Join daryl2cb@yahoo.com's club!
https://ls1tech.com/forums/showthrea...iming+200+shot
Old Mar 8, 2006 | 11:54 AM
BADBOYZ28's Avatar
Read it and still didnt answer all my questions!! I'll add some of the info. that 383LQ4SS requested.........Its a single stage, CR is 11.0 to 1, has forged internals minus crank!! Hope this helps out some more.
Old Mar 8, 2006 | 10:40 PM
oange ss's Avatar
you might have to pull 3-5 degrees out to run a 200 shot with 93, you can go a little more if you run the 104...the only way to tell is run it and log KR, every car will react differently to the same scenerio
Old Mar 9, 2006 | 10:30 AM
wilddawg's Avatar
retard timing 1.5 degree per 50 hp. I usually pull out 4 degrees for 200 shot because I don't retard for anything under 100 hp.
Old Mar 9, 2006 | 02:45 PM
BADBOYZ28's Avatar
So then I should run about 22-24 degrees since I'm at 28 right now. What about a/f what should it be at more or less? 12.5 or so?
Old Mar 9, 2006 | 03:42 PM
white2001s10's Avatar
Do you have any data-logs of a recent motor pass?
I could compare off of that and tell about what it will need.
Old Mar 12, 2006 | 01:11 AM
BADBOYZ28's Avatar
Actually no I dont!! I logged them but didnt save any of them ,but I can more or less tell you what you need to know. What info. you needing?
Old Mar 12, 2006 | 11:12 AM
frame by frame of RPM, speed, and spark advance.
Old Mar 17, 2006 | 01:49 PM
daryl2cb@yahoo.com's Avatar
Originally Posted by Somebody09
I don't get it, or at least I did not reply to the thread referenced above.
Hopefully I gave good advise though, retard at WOT till knock is gone, is usually what I do
