Tuning for N2O Questions..
Old Mar 9, 2006 | 01:03 PM
Solid GraphiX's Avatar
Default Tuning for N2O Questions..
I'm just wondering what I should be running timing and a/f wise...
The kit is dual stage dry shot then wet shot with propane.
First stage is 100 dry
Second is 150 wet with propane.
Just wanting to get the most out of it!
Old Mar 12, 2006 | 07:38 AM
Guess I'm on my own with this one...
Old Mar 12, 2006 | 09:04 AM
n2ocamaro's Avatar
Optimum timing and AFR is going to vary depending on the set-up. Especially since you are using propane for enrichment. You will just have to spend some time on the dyno to find the sweet spot
