Does your NX bottle opener get stuck?
Old Mar 9, 2006 | 11:34 PM
THE LAST Z's Avatar
Default Does your NX bottle opener get stuck?
What it says. Most times Mine wont open. I can hear the motor tryin, but cant get it open, like it doesent have enough torque. Then after 20 trys, it works, and then the bottle is stuck open!
WTF???
Old Mar 10, 2006 | 07:27 PM
GTOtoGO's Avatar
Adjust the clutch.
http://www.nitrousexpress.com/Instructions/opener.pdf
Old Mar 10, 2006 | 08:23 PM
Screamin_Z's Avatar
mine did, I even adj the clutch so I got rid of it and got a DynoTune opener...works flawlessly
Old Mar 11, 2006 | 07:18 AM
BadAssFast's Avatar
WTF???
Aside from the clutch adjustment, is the motor housing seated all the way? How's the valve itself. NX has great tech support.
Old Mar 11, 2006 | 12:17 PM
SmaknaSS's Avatar
Mine does somtimes but I'm not too worried about it. I think I just need to ajust it a little.
Old Mar 11, 2006 | 01:46 PM
THE LAST Z's Avatar
ok ill adjust the clutch and see. Thanks guys.
Old Mar 11, 2006 | 10:49 PM
Somebody09's Avatar
lol, mine used to do that. I played around w/the clutch. Can't ask me what I did 'cause I don't remember!
Old Mar 12, 2006 | 12:34 PM
GTOtoGO's Avatar
Make sure the valve is open when the opener is installed.
Old Mar 12, 2006 | 07:49 PM
BadAssFast's Avatar
For those who don't know...gently pry the protective cover off...take the appropriate sized wrench...12mm? don't recall...clockwise turns will tighten the clutch. The other thing is before you start is to be certain the opener is seated all the way down on the nut that actually turns the valve so that it engages the motor's gear assy and does not strip it out. Reinstall the cover.
Here's the link: http://www.nitrousexpress.com/Instructions/opener.pdf
Old Mar 17, 2006 | 01:41 PM
daryl2cb@yahoo.com's Avatar
NO problems here, the clutch adjustment should help though
