nitrous trouble shooting
Old Mar 11, 2006 | 12:02 AM
WheelsUp84z's Avatar
Default nitrous trouble shooting
whats up, i finally got my nitrous hooked up, and when i turn the switch on to arm it, the light comes on as if it has power to the system, but it doesnt work., im running a nx wet shot, i have it to a wot switch and a window switch, is it possible that one of them is bad? i even pulled the nozzle out of the intake and held the car at 3500 rpms and pressed the WOT switch manually with the system armed to see if anything sprays out..which it didnt. Im lost to as what could be the promblem other than a bad switch, maybe the relay?? how can i trouble shoot that? i dont know anyone have any ideas? thanks in adance
Brandon
Old Mar 11, 2006 | 01:41 AM
Mr.Nitrous's Avatar
Recheck all of your wires to make sure they are correct. If using an msd window switch, are you using the right wire to trigger the relay? Sounds loke a crossed up wire.
Old Mar 11, 2006 | 01:50 AM
ive checked them like 10 times, but i can check them again ill even tell you what color wires i have hooked up to what and you can tell me that the book is wrong or that i am wrong in the way they are wired up.
Old Mar 11, 2006 | 01:56 AM
Mr.Nitrous's Avatar
Are you running a fuel pressure saftey sw. . If so is it set at the proper press.?
Old Mar 11, 2006 | 04:03 AM
SDB's Avatar
SDB
If you have a FPSS, try making a jumper wire to connect the two sides together (bypassing the switch and making a solid connection)...sometimes that is the cause of a kit not working.
Replace the relay that is used for the solenoids
make sure MSD is wired correctly, meaning that the "proper" modification was done to the internal portion to make it work with LS1 engines....see MSD tech for more info on this...
tey these things first
SDB
Old Mar 11, 2006 | 09:37 AM
well first off, i dont have a fpss, secondly its not on a ls1, its on a grand prix, im going back over every single wire today to check yet again, then ill change out the relay..we'll see what happens from there
Old Mar 11, 2006 | 10:54 AM
227Hawk's Avatar
I'd check power @ the solenoids and the grounds too. Alot of times it's the Simple things that drive you 'nuts'
Hawk
Old Mar 11, 2006 | 11:36 AM
BadAssFast's Avatar
Brandon
Brandon, i've been troubleshooting electrical systems for many years. The first mistake that lots of people make is just guessing what is bad...a switch...a wire...a whatever. My advise:
Get a pencil and paper and make an exact diagram of YOUR connections on paper. Double check everything. Add what volatges should be a what connection if all is working.
Download a simplified diagram from ls1tech...search on "Nitrous wiring".
Get an inexpensive volt/ohm meter and start checking.
What I see everyday is people trying a hit and miss method hoping the answer will just suddenly become evident. It might if you are lucky. It will verify your total; system integrity if you troubleshoot.
Old Mar 11, 2006 | 11:18 PM
916marine's Avatar
it was the damn WOT switch afterall, after about 2 hours of testing every whire, i just ran straight power to the wot switch then to the solenoids and nothing, then i just rand a power wire to the solenoids and touched the ground to the neg on the battery and boom it worked, so im glad i got all of this mess figured out, too bad im pulling the system to put in my buddies 98z28, that stuff happens when you get pissed off and get fed up with certains things..oh well
Old Mar 12, 2006 | 06:08 AM
227Hawk's Avatar
Macon hows your car running? I'm probably still 2 weeks away from having mine put back together.
Hawk Here's a teaser
Old Mar 12, 2006 | 10:32 AM
BadAssFast's Avatar
Time...time...time. Everything is complete for this phase except for tune/dyno. We will takle tune Thursday in Charlotte...maybe dyno tuner too. Assuming all that goes well...we unveil this at a SVT/Cobra Race at the 1/4 mile at Carolina Dragway on 3/25. (Like the guys who cae don't alrady know !) New Bogarts arrive on Thursday.
Now - for yours - so much for a single stage? A little Cold Fusion Direct Port happening? (Well maybe not little in the comparison sense!) I guess we'll have to meet at some track between here (South Carolina) and California. I swear I keep hearing Texas calling!! Looking good . I'm sure your car is still cleaner than mine!!!
Old Mar 12, 2006 | 11:12 AM
227Hawk's Avatar
Yours, I knew your runs were coming up. Good luck and let us/me know how they turn out.So your going for skinnies too? Damn you be throwing some cash @ that car. With that 408 and Dave's kits you should run great.
Macon
Mine, Been playing with my 1 stage then 2 stage dry.Felt the need to throw a D.P. on top. The fuel line split is what's holding me up. The welder
hit my AN fitting with the TIG. Then off to the powder coaters. I'm staying with 285's on all 4. Going for the sleeper look.
Hawk
