Nitrous Dave's Trick Window Switch Wiring
The only benefit i could see is that one way if the fpss trips it wont turn off the window switch just the relay, but if you wired it btwn the chassis ground and the window switch it would shut of the entire window switch correct?
would one way be better than the other?
IF you go throu fpss for the ground for your window switch and that window switch has a read out, you could easliy tell if the fpss is working or not. YOu would not see anything on the read out, IF you do not enough fuel pressure to close the contact on that FPSS.
Kinda of a tell tell if you should even try the nitrous a warning light for fuel pressure I guess you could call it.
Sorry for the delay in answering the ? got side tract.
Ricky
PM me your email address and I'll email you the diagram.
I'm too lazy right now to upload it.
The only expetion is if you use a WOT switch wired up to the pos side of the relay coil, and use the window switch on the neg side of the relay coil.
Not using a two stage kit so Blue and Orange were not used.
As stated above...I do not need to wire blue wire to TPS if I am using the green wire for the tach? Even though it will spray at the window I give it with the tach signal, how will the system know it's WOT without wiring the blue signal to the TPS? I do not need to run the blue wire unless I have a mechanical WOT switch hooked up?
You do need to use the blue wire since you have acc power to pin 86 on the relay.
Ah ok, so since I AM directly connecting the ACC to pin 86 on the relay, I have to use the blue TPS wire. That's what I figured. Thanks again!
My question is what is the preferred location for the FPSS in this wiring scheme? I thought the common place was interrupting the yellow run from the trick window/wot switch to #85? However this thread indicates you could use it to interrupt the window switch ground? Is either more advantageous?
And out of curiosity, could you also wire the FPSS in the ground for the fuel and nitrous noids? Seems like that should work too.
One other question...whats the recommended fuse rating that should be inline between the battery and #30 on the main relay?
Thanks guys, there's been alot of extremely helpful folks in this thread.
