First time I melted
After making some passes with my new Fuddle converter:
N/A passes
1.750 7.579 92.63 11.874 114.17
1.668 7.489 94.31 11.763 115.08
1.647 7.486 91.63 11.789 114.48
75 shot
1.659 7.201 97.41 11.254 121.29
100 shot
1.625 7.004 100.21 10.936 125.30
150 shot
1.642 7.229 92.20 11.747 106.58 lost power due to melted plugs and head gasket.
Yes it was, I'm getting use to it, just had it towed home that past Monday for the the trans line coming offing and the trans shutting down.
I was worried when I drain the oil and it was a little milky, but I flushed to good and the oil pressure seem good, so I got lucky
I'm not sure of my A/F stock fuel table with 25-26* on 92 octane, I'm sticking with 23* from now on
i would recomend a leak down on the motor, but thats your call. depending on how bad it melted.
how old are your injectors? have you ever had them flow matched? cleaned?
sounds to me like you may need more octain or less timming. but it could be other issues.
I'm going to check the fuel solenoid, check the fuel pressure, change the fuel filter, run some injector cleaner.
I also have a hot wire kit I need to install, but haven't got around to
The injectors were used, so I'me not really sure how many miles.
I changed the conveter because the Yank SS4000 was to loose for me daily driving.
Did I answer everything?
( I think thats a first for you). Did I mention to you I see no difference in ET/MPH running 24* compared to 28*? I ran the 24* on the one halfassed run with both stages, no KR, no lean spots, it all looked good. Might be hotwire helping, but the shot size your running shouldnt REQUIRE the hotwire kit.
( I think thats a first for you). Did I mention to you I see no difference in ET/MPH running 24* compared to 28*? I ran the 24* on the one halfassed run with both stages, no KR, no lean spots, it all looked good. Might be hotwire helping, but the shot size your running shouldnt REQUIRE the hotwire kit.I haven't been running race gas either?
