hey guys new to ls1 tech have a question
Old Mar 19, 2006 | 09:16 PM
BLK02Z's Avatar
Default hey guys new to ls1 tech have a question
i have a 02 camaro with exhaust lid filter slp bellow and i just ordered the plate nos system for my car how much nitrous can i use with what i got
Old Mar 19, 2006 | 09:24 PM
383LQ4SS's Avatar
maybe start with a 100 shot. Run that till your used to it...which will probably be a week or two...lol. The up the pills to a 150.
Be sure to change out the plugs for some NGK TR6. And use a window switch too.
Good luck..youll love it.
Old Mar 19, 2006 | 09:25 PM
iamsickofitall's Avatar
100-125 without running out of fuel - i'd really monitor things if i tried spraying more
Old Mar 19, 2006 | 09:26 PM
BLK02Z's Avatar
i htought that 100 would be good thanx oh and what do you guys think of the nos sys
Old Mar 20, 2006 | 07:15 AM
TN94Z's Avatar
I used the NX MAF kit on my 98 with a 150 shot. I think that the stock fuel system is good to 150. I would change the plugs and definately keep an eye on things. After a couple of hits with the 100...you won't be able to stay away from the 150!!
Old Mar 20, 2006 | 08:34 AM
Big Geek's Avatar
A 150-shot should not hurt anything so long as everything is in good working order. I would make sure to install some NGK TR6 plugs and close the gap to .035-.038 . If you are unsure about your fuel system just mix you up 5 gallons of 93 octane and 5 gallons of 110 or 112 octane for a total octane rating of 101.5 (93/110) or 102.5 (93/112). This will make sure that you are more than safe in regards to octane. Some will tell you that you don't need that much octane or that much fuel in the tank but until you get used to running nitrous those few issues will provide you a good safety net and loads of passes without issue suffice that all else is as it should be. Hope this helps.
Jim C.
