Why Doesn't EVERYBODY Run One?
http://www.dynotunenitrous.com/store...p?idproduct=67
Reading the description, it seems like this would be one of the most wildly popular nitrous products on the planet.
Any idea why it isn't?
(and much, much more, thus reducing the need for 50 extra stand-alone units for this-and-that stuff.) Trending Topics
Here is where my LM1 is mounted,
Robert
I also have a LC1 sitting here now
what ever brand size or model you chose it is a good choice
Robert
Yes on an LS1 it is VERY easy to hook up and set up. Hook up a few wires at the PCM(RPM and WOT) and install the Wide band Sensor. This will still leave with Room to grow on unit in the future. The Programing is very simple to setup also. IF you are using a Dry kit You will need to set it up for the lean spike at the begining of the hit.
I decided to go with a 2 channel FJO wideband. It has settings to shut down the nitrous if it gets too rich or too lean. Plus it has a built in TPS and window switch so you don't have to buy them extra. It wasn't cheap but neither is fixing a blown motor.
Yes it won't help if the nitrous noid sticks open but with a quality noid that problem seems rare these days.
Ricky
