125 dry set up
Old Mar 24, 2006 | 10:37 AM
chris2000ss's Avatar
Default 125 dry set up
hey guys i want to add a 125 dry shot to my set-up.I will be up grading my fuel pump to a racetronix P/P and doing injectors at the same time.my question is ,will 30lb svo injectors be sufficient ?? I dynoed 414 rwhp with current mods in sig.
Old Mar 24, 2006 | 11:28 AM
Matt D's Avatar
Retired Street Racer
What was the duty cycle on the dyno pulls?
Old Mar 24, 2006 | 12:12 PM
i honestly dont know I'm running the stock 26lb now.
Old Mar 24, 2006 | 12:27 PM
Matt D's Avatar
I would go with 42lbs to be safe. They are easy to tune, and give you more room to grow than the 30lbers.
Old Mar 24, 2006 | 12:58 PM
I was thinking the same.should I go with the delphi's or Ford 42lb ??
Old Mar 24, 2006 | 01:00 PM
Matt D's Avatar
The Ford (SVO). That is what I use, and many others with great success.
Old Mar 24, 2006 | 03:17 PM
sounds good,any recomendations on where to get a set??did you have yours flow matched?? sorry for all the questions
Old Mar 24, 2006 | 08:41 PM
Robert56's Avatar
Look in my web in the links section for a sight that has the best prices for the SVO's. I also run the 42lb SVO's.
Robert
Old Mar 24, 2006 | 09:13 PM
227Hawk's Avatar
P.M sent
Hawk
Old Mar 25, 2006 | 02:49 AM
Matt D's Avatar
We can order you a set through our shop. I did not get them flow matched as I don't believe it is necessary.
Old Mar 25, 2006 | 07:50 AM
thanks for the replys,i'll get the 42lb svo's
