Lights on the FJO?
Old Mar 27, 2006 | 04:16 PM
02Vortech's Avatar
Default Lights on the FJO?
hey i know that the red light is the TPS @ least i think, what is the yellowish light on the FJO?
Old Mar 27, 2006 | 04:28 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Green is tps
yellow stage 1 window is met
red stage 2 window is met
Ricky
Old Mar 27, 2006 | 04:47 PM
02Vortech's Avatar
o lol thank you sir- i dont have a second stage set-up though hmmm......- the red light is only comming on when i press on the gas and the first stage is on all the time.......... any ideas?-
i should also have it set to
Trigger switch will enable this stage ---- for stage 1 correct?
Trigger switch will disable this stage ----- for stage 2 is this correct?
Also i went WOT and the solenoids clicked on/off very rapidly for a couple seconds- but now they dont they just open @ WOT- any ideas why that i was? just wondering
Old Mar 27, 2006 | 06:12 PM
02Vortech's Avatar
bump!
Old Mar 27, 2006 | 11:15 PM
cyipher's Avatar
Well if your not using the second stage just unclick the present box, make sure you tapped the right wire for the tps and that you have it set to voltage rises.
Old Mar 28, 2006 | 12:38 AM
frknlo's Avatar
The trigger switch doesnt necessarily need to be used. I use the controller for only a single stage with the trigger switch not hooked up and it still works for me.
Old Mar 28, 2006 | 08:36 AM
NXRICKY's Avatar
I need to see how you have it programed and wired.
Ricky
