Pics need ASAP!
Old Mar 27, 2006 | 07:34 PM
goodrich969's Avatar
Default Pics need ASAP!
Im looking for some pictures of a LT1 with a simple nitrous set up, just a wet shot. I need to see where the solineods should be placed and what was used, because i have a kit and im not sure how i want to set it up. It needs to be very simple. Please hook me up with some pics, Thanks alot
Old Mar 27, 2006 | 07:58 PM
30thz's Avatar
Old Mar 28, 2006 | 05:41 AM
i like the simplicity, how did u mount the brackets, because i only have 2 of them a nitrous and a fuel solenoids, obviosly but how did u mount them that way. Also how much do those two braided lines cost?
Old Mar 28, 2006 | 08:33 AM
got V-8?'s Avatar
I thought you hooked ot up last night and ran it?
Old Mar 28, 2006 | 08:40 AM
yeah but when i took it off, i found out that it wasnt holding right and my solinoeds were dangling because of the fuel and nitrous tubing that i got with my kit, i need to get some braided cord.
Old Mar 28, 2006 | 12:48 PM
30thz's Avatar
I just bent the NX brackets and mounted them using the bolts that hold the fuel rails down. The braided line canme with the kit but I did upgrade to the show line on the N2O side (around $21)
Old Mar 28, 2006 | 06:24 PM
Nitro Dave's Nitrous Outlet's Avatar
Nice clean install. Good job.
Dave
Old Mar 28, 2006 | 06:32 PM
30thz's Avatar
Thanks everyone, thats actually an old picture, it looks even better now with Dave's shiny stand alone and new CAI!!
It would look even better with a direct port! (Damn I hate being poor)
Old Mar 29, 2006 | 05:43 AM
where would u put ur jets if u didnt have a nitrous plate?
Old Mar 29, 2006 | 07:21 AM
30thz's Avatar
When I was running the nozzle I had it Where your I.A.T. would go, I had a relocation harness for it.
Yo what it as straight as possible facing the intake. Also make sure it doesn't interfere with the hood.
Old Mar 29, 2006 | 08:40 AM
I.A.T? do u have any picture by chance? THanks
Old Mar 29, 2006 | 08:46 AM
got V-8?'s Avatar
I.A.T. - Intake Air Temp sensor
Old Mar 29, 2006 | 06:53 PM
30thz's Avatar
The top picture is when I had the 1LE elbow the second where the red circle is where your I.A.T. would go I put the nozzle there becuase I didn't want to drill the Tricky flow elbow. Hope this helps.
Old Mar 29, 2006 | 07:06 PM
it sure does 30thz, so jus for clarification, the solinoeds are mounted where on the fuel rails? it looks like u have a purge solinoed?
Old Mar 29, 2006 | 07:33 PM
30thz's Avatar
yes, front two hold down bolts then bend the noid brackets to desired shape, and yes the small moid is a purge.
Old Mar 29, 2006 | 08:56 PM
30thz did u need 4 sets of lines, the lines to the solinoeds then from the solinoeds to the jet? i only have 1 feed line, from the bottle, where does that go? do i need another line for the other solinoeds
Old Mar 29, 2006 | 09:21 PM
30thz's Avatar
http://www.nitrousexpress.com/Instructions/stage1.pdf
This should help.
Old Mar 29, 2006 | 09:27 PM
yeah one quick question, where did u get the fuel supply from, i kno the fuel line. but where at and how did u do it.. Thanks 30thz youve been alot of help so far
Old Mar 30, 2006 | 05:22 AM
30thz's Avatar
Remove the schrader valve from the threaded fuel port, on the rear of the manifold. It's kind of like a bicycle tire valve. And then thread your line in to that.
Old Mar 30, 2006 | 05:29 AM
so the line should jus screw into that schrader valve? Thanks
