Which Progressive controller?
Dan
2 fully independent nitrous controllers in one small bulletproof case
Hand held programmer for ease in programming
Allows you to mount the main box out of sight
Integrated throttle position activation switch eliminates the need for a separate WOT switch
Progressive nitrous ramps feature:
a) Delay time programmable from 0 to 9.9 sec.
b) Start percentage programmable from 0 to 99%
c) Ramp time programmable from 0 to 9.9 sec
d) End percentage programmable from 0 to 99%,
e)Nitrous can be programmed to ramp up or down
RPM on/off control eliminates the need for a separate window switch
Solenoid control channels with a 40 amp load capacity for large solenoids
Two output signals for use with timing retards or activation switches
The part number is 15974NOS it can be bought thru any NOS retailer.
* 2 independent channels
* Programmable ramp times (0.1 - 10.0 sec)
* Programmable delay times (0.1 - 10.0 sec)
* RPM or Time based linear ramp or multi-point curve
* Integrated wide-open-throttle detection
* 1st gear lock-out
* User configurable for rising or falling TPS signal
* Supports low voltage tach signals as low as 3 volts
* Works with irregular tach signals such as V10 and 3cyl
* Easy to use graphic set-up menus using PC USB
* Inputs for manual enable/disable or transmission brake, throttle position, tach signal
* Integrated LEDs for WOT, stage 1 RPM window, stage 2 RPM window
* High current solenoid driver with 40 amp load capacity (continuous duty)
* RPM trigger window switch
-Dan
We have these in stock as well.
Dan
Here is a Link for a brief description (basiclly what Jay said) and the complete instructions for the 15974NOS 2-Stage controller.
Thanks,
Kyle
I should recieve it on monday. Matt was real helpful to, great to work with. Excited to try the controller!
Dan
