wiring diagram
Old Mar 29, 2006 | 04:19 PM
smokeum99ta's Avatar
Default wiring diagram
I need a wiring diagram for a MSD (non digital) windows switch. I'll be using WOT switch. I have the NOS 5177 kit.
Old Mar 29, 2006 | 04:55 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Just leave off the fuel solenoid.
Hope this helps.
Ricky
Old Mar 29, 2006 | 06:38 PM
cleveland's Avatar
piggy backing...
how bout the single unit fjo mini-controller instead of the MSD unit and a fuel pressure switch?
-Dan
Old Mar 29, 2006 | 06:56 PM
NXRICKY's Avatar
Dan, the FJO controller comes with a diagram. Not sure which one you are looking for?
I will be more than glad to help, but need a little more info.
Ricky
Old Mar 29, 2006 | 07:29 PM
Hope this helps.
Ricky
Thanks ricky.
Old Mar 29, 2006 | 09:55 PM
Robert56's Avatar
There is a specific 5177/MSD wiring diagram in the stickies.
Robert
Old Mar 29, 2006 | 09:58 PM
cleveland's Avatar
Ricky
alright, how does a fuel pressure safety switch get wired into the wiring diagram for the 2-Stage Progressive Mini-Controller (diagram 11)?
Do I just wire the ground wire from the relay to a contact on the pressure switch and then wire the other contact to a ground on the chassis?
Thanks!
-Dan
Old Mar 29, 2006 | 10:13 PM
NXRICKY's Avatar
Thanks!
-Dan
The FPSS can break any low amp control wire, but the ground going to the relay is a perfect one in my mind.
Ricky
Old Mar 29, 2006 | 10:44 PM
cleveland's Avatar
alright, now only if I can figure out which numbered prong goes where.
edit: #30 to +12v
#86 from activation circuit
#85 to -12v (fuel pressure safety switch then grounded)
#87 to solenoids
Is this correct?
-Dan
