Tuning
Anyone here used the IAT to power enrich on a dry shot? I wonder if the IAT will read my dry shot because my single nozzle is on the pass side. I will do some logging soon and find out. Maybe there is no reason if the maf is reading the nitrous flow correctly. I got my bigger injectors & HP Tuners & I am exploring all the possibilities.
Using the MAF you'll be using your WOT Power Enrichment fuel multiplier, the same wot a/f that you use n/a. Now using the power adder vs IAT table will add an additional multiplier on top of the above. It adds the two multipilers together while spraying only. Hope this clarifies this a bit. Nozzle location can have an effect on when, how quick and how well the iat sensor reads.
Robert
Robert
