dumb and quick question
Old Mar 30, 2006 | 07:02 PM
Y2kforgedSS's Avatar
Arrow dumb and quick question
Ok im new to this timing tuner stuff but im just wondering if there is a write up on the install or if anyone could tell me were the connection with the grey and white wire run to?
thanx for the help
josh
Old Mar 31, 2006 | 06:20 PM
Come on guys i know one of yall know!
Old Mar 31, 2006 | 07:04 PM
BadAssFast's Avatar
Man I simply have no idea what you are asking. Be more specific.
Old Mar 31, 2006 | 07:11 PM
227Hawk's Avatar
I'm thinking wire schematic for a Timing Tuner.
I can't help but, here's TTT
Hawk
Old Apr 1, 2006 | 01:08 PM
Thanx guys. Ok ill try to be more specific, there's the 3 connections right, well (1) there is the connector that connects into the mafs wire from the pcm (2) then the other that just goes in place of the connector coming off of the mafs. The (3) connector has only 2 wiers running to the actuall connector, a white and a grey wire, what does this plug into? I hope that will help my problem out more.
Old Apr 1, 2006 | 01:42 PM
sleeperstyle's Avatar
http://www.ls1speed.com/pdf/LS1TT.pdf#search='timing%20tuner'
took me 2 minutes to find copy and paste. the schematic is on the very bottum of the left side scroll section.
Old Apr 1, 2006 | 05:36 PM
Thank you very much that is exactly what i was looking for. I feel stupid cause i looked and found nothing and it only took you 2min.
thanx again
josh
Old Apr 1, 2006 | 07:28 PM
www.yahoo.com
it's all good. good luck w/ the install.
