nitrous results are in
what ya think?
Do youself a favor and install a PLX wideband for 250 bucks so you can see EXACTLY what the car is burnin .
When you throw some hot *** burning race gas in with nitrous or boost you can melt a motor at 12.0 .
The problem with dry kit is , you cant physicaly adjust your a/f in the hot summer or cold *** winter .
So at mid summer you will run pig rich and in the winter you run dangerously lean , asuming the car was setup on a 75-80 degree day .
If someone tells you you can spray a 150 shot dry , you might want to talk to some different ppl before they help you torch your motor .
Oh, by hte way, who has torched their motor running a dry hit? likely it'll be far and few between, if you find any at all.
Robert
