New Nos set up
I tested the nos solonoid and nos shoots out from the noid when I press the WOT switch with the engine running and the widow switch set down at a low rpm just for testing. I have it set to 3,000rpm on and 5,700 off for now.
Anyway I do a road test with the smallest jets 50hp and it kicks in like a mule!
It's like I have a turbo when I hit 3,000rpm all hell breaks loose. So it seems to be working fine.
So Just to make sure I'm spraying in the extra fuel aswell I do the same test on the fuel noid. So I remove the nozzle from the intake and spray it through the 50hp jet. (Number 20)
What suprizes me how little fuel comes out!
Thers's not much in the way of pressure there, it's a trickle.
Has anyone else tested there setup this way and seen the same thing?
That's cool there is no doubt the systemis working I felt hell of a kick when it hit 3,000rpm
Glad the system is working well for you, now up the horsepower setting an let it rip!
I figured if I going to spray I might as well spray at least 100hp to get me in the 12's hopefully when I take it to the track.
Cheers Andy
