Pros/Cons of a direct port setup?
Old Apr 7, 2006 | 05:16 PM
98TADRIVER's Avatar
Default Pros/Cons of a direct port setup?
I was thinking about a direct port setup, maybe 100 shot for now
I just need some thoughts on it, what are the pros/cons of having a directport setup on my car?
does it cost more than a standard wet kit setup?
higher power & torque gains at the Rear wheels?
any downsides to this? i heard of intake manifolds blowing off !
i might score an intake manifold with direct port fittings for a good $$
thank you!
Old Apr 7, 2006 | 06:56 PM
Airwolf's Avatar
Pros:
-Seems to be safer (IMHO) then a single nozzle (if done correctly of course).
-Looks cooler.
-Able to do bigger shots then a single nozzle.
-Less chance of a manifold back fire.
Cons.
-Cost of system is more then a single nozzle.
-You will need to regulate fuel pressure to do smaller shots then 250 due to fuel jet size (small shots equals scary small fuel jets). Low pressure fuel equals large fuel jets with less chance of clogging.
-Time to install.
-Changing shot size can and does take close to an hour for 16 jets.
-Tuning can take longer.
No real advantage in more HP then same rating of a single nozzle system, again just the ability to go bigger in the long run and be safer.
This is just my opinion on DP. Others will vary...
Old Apr 7, 2006 | 06:58 PM
98TADRIVER's Avatar
thanks! anyone else?
Old Apr 7, 2006 | 07:46 PM
ApacheDrill's Avatar
I wouldnt waste my time or money with direct port for 100 shot.. 250 or more, you can get a plate kit or nozzle kit to do what u need it to for 100 shot.. Most go with direct port for bigger numbers..
Old Apr 7, 2006 | 07:49 PM
98TADRIVER's Avatar
thank you, i shall keep that in mind!
Old Apr 9, 2006 | 05:28 AM
chpmnsws6's Avatar
You run the chance of all the nitrous hitting one or 2 cylinders instead of all 8 equally. 100 hp of nitrous in a single cylinder might hurt it just a bit. Doesn't most the nitrous hit cylinder #7? it always seems to be the one to go first
Old Apr 9, 2006 | 05:41 AM
anarchy99's Avatar
I'm doing a 100 shot on a direct port setup... like said before, Pain in the *** to get to the damn jets!!!!!!! Looks cool though and if it looks cool, it's gotta be right, right?!
Old Apr 9, 2006 | 10:08 AM
Toonz's Avatar
Like mentioned above I wouldn't do DP for a 100 shot, there are much simpler and just as effective methods for that small of a shot. The looks can be there for all methods if you want it to be, just takes time. Or you could go with Dave's hidden system and not see anything under the hood.
If you plan on spaying 250+, either now or in the future, then DP would be the route to go. JMO though...
